Old 02-16-2022, 04:51 PM   #72 (permalink)
aerohead
more means more
Originally Posted by Isaac Zachary View Post
This is how I understand it too.
Plus more mass means more weight which means more rolling resistance.
Ideally all cars, with regen or not, would weigh as little as possible. A 1,000lb car will take about 1/6 the energy to accelerate to a particular speed than one that's 6,000lbs. If regen is 80% efficient on the 6,000lb car and the 1,000lb car has zero regen you'd still be using more net energy to accelerate and decelerate the heavier vehicle with regen than the lighter one with no regen.
When you run the numbers you'll see what the authors of the thesis were eluding to.
Then you can consider options.
There is no energy to decelerate. Only energy recovery.
