Old 02-16-2022, 06:45 PM   #80 (permalink)
Isaac Zachary
High Altitude Hybrid
Avalon - '13 Toyota Avalon HV
90 day: 40.45 mpg (US)
Prius - '06 Toyota Prius
I recommend that you examine testing cycles and the other physics necessary to flesh out the details associated with the thesis.
You're describing dynamics that are not prescribed within the constraints of the mandatory test protocols.
The things you mention can all be numercalized.
All the mathematics will be required to have an actual look at what's discussed.
Without the mathematics we cannot proceed.
I examined the testing cycles and did the math and came up with the same conclusion that there is no "goldilocks" mass in a BEV. The evidence I see points to lighter as being more efficient overall, even though it is true that less kinetic energy can be recuperated from regen making it appear to be less efficient when it really isn't.
The Following User Says Thank You to Isaac Zachary For This Useful Post:
aerohead (02-16-2022)
