Old 02-18-2022, 01:18 AM   #16 (permalink)
cRiPpLe_rOoStEr
I remember seeing mentions of the usage of 2-stroke oil in fuel to prevent rust in the carburettors of some older vehicles due to the ethanol blends on gas.
Think you have the valve materials switched, maybe, and 100/110 "lowlead" avgas has multiples of the car lead quantities. It is lower lead than 145 fuel and 80/87 is not readily available.
20 years ago I was able to have hardened faa approved seats installed in my O-290 lycomming and all the rubber parts were replaced with new style alky resistant AN hoses so I could buy a stc for cars gas.
Nowadays there are even ethanol-powered aircraft. AFAIK cropdusters in Brazil are now using ethanol more often than AvGas.
