Old 02-23-2022, 06:10 PM   #1 (permalink)
Plush1992
War Pig - '01 Ford Taurus SEL
1994 Mazda B2300 2.3l Project
I own a 1994 Mazda B2300. It's identical to a Ford ranger. Main difference is it has sequential fuel injection. No A/C. No power steering. It has the 3.08 highway gearing, I can't go any lower.
I want to improve it's power output and MPG while still keeping it as a daily driver and use as a truck with a bed.
Mechanically it's in great condition.
- I've replaced all fluids. Fully synthetic in the rear end and transmission. Sticking with oem standard fluid for the engine (I don't want a potential leak).
- I removed two air baffles in the intake system.
- Installed a new K and N air filter.
- Brand new 215/75/15 Hancock tires all season light weight tires.
- Partial grill block. Front air dam (needs to be fine tuned)
- Roll up tonneau cover.
- Stick shift.
- Led head lights
I want to close the gap for the wheel wells. Do some under body work at the rear end for aero. I'm also working on an electric fan.
Any other ideas as to what to do???
First: 2001 Ford Taurus Eco Build Thread
http://ecomodder.com/forum/showthrea...s-33334-2.html
The Following User Says Thank You to Plush1992 For This Useful Post:
Ecky (02-25-2022)
