Old 02-23-2022, 07:20 PM   #2 (permalink)
Plush1992
War Pig - '01 Ford Taurus SEL
Some more pictures. New duel core allumiun radiator. Wrapped headers and Egr tube. I used a rubber seal to close the gaps at the hood and between the bumper and grill. I noticed right away engine noise was cut down.
I installed a partial grill block. I did this once before and went for a 50 percent grill block. It was mid summer, I had an old single steel core radiator and it would heat up too much and loose power. I'm thinking this smaller grill block with the better radiator should do well. I'm installing an electric fan and the cooler the truck runs the less it will have to turn on and the less power it will rob.
ID:	31731   Click image for larger version
ID:	31732   Click image for larger version
ID:	31733   Click image for larger version
ID:	31734   Click image for larger version
First: 2001 Ford Taurus Eco Build Thread
http://ecomodder.com/forum/showthrea...s-33334-2.html
