Old 02-25-2022, 02:06 PM   #666 (permalink)
freebeard
C) You're characterization of my behavior could land you in court. Watch your mouth
Should I put on some popcorn?
I looked at # 648 ( permalink )
I refuse to look at it. I don't recognize it as a reputable source for information.
So... which is it?
Either you know things or you don't. If you can't tell us directly about something without referring to someone else, I've zero confidence that YOU have any command of the information whatsoever.
This is how it's going to work.
I don't think you could play on a level field, unless you stop rejecting current peer reviewed research.
You might familiairize yourself about Epistemology. Then get back to us.
