Old 02-26-2022, 01:02 AM   #50 (permalink)
EcoCivic
I think I finally figured out a solution. In Kpro, I believe I can set a speed for nitrous to activate at. If I connect a normally closed relay inline with the ECU's fan activation wire and activate it with the ECU's nitrous output set to come on at 35 MPH minimum with minimum RPM, load, and throttle position set to 0, I think that should do it. I plan to get Kpro as soon as I can anyways, so this seems like a simple solution. I'm still trying to think of a way to make this work with a stock ECU though.
