Old 02-26-2022, 06:22 PM   #12 (permalink)
Isaac Zachary
High Altitude Hybrid
Avalon - '13 Toyota Avalon HV
90 day: 40.45 mpg (US)
Prius - '06 Toyota Prius
Yes, there are advanced stability control systems that incorporate throttle with braking. I really doubt the OP is going to do that kind of coding and controls with his home project
The difference between fuel on and fuel off engine braking is small - but it can be enough to make a difference in the right conditions. That is why you wouldn't want to set the engine to always turn off when the throttle is lifted fully.
When I lived in TN our neighborhood was up on a hill. It had an 18 degree drive up from the main road (yes, I measured it with an angle finder). With our truck in 2wd mode that hill was dangerous to go down in the snow. If you let off the gas too quick or too much the engine braking was enough to break the back loose and you wouldn't gain control again. Sideways slide down the hill into the main road. The only way to safely descend that hill was to go down in 4WD low and just let the truck idle down the hill or chain up and drive down - then unchain at the bottom.
A car with an automatic will only start the engine in neutral or park. It has an interlock to keep if from attempting to start in gear and having the starter propel the car forward. A car with a manual transmission will only start in neutral or if the clutch is disengaged. It has an interlock to keep from attempting to start in gear and having the starter propel the car forward.
Same with a homemade mild hybrid system. You wouldn't want it to start the car in gear with just a touch of the throttle unless it is in neutral or the clutch is disengaged.
You mention twice about adding a switch to decide when to active the stop / start. It would be easier to tie into to the neutral switch. Shift to neutral - the engine turns off. Shift back into to gear - the engine turns on when the clutch starts to release.
Maybe there's one thing that I'm thinking but isn't mentioned here: putting the swtich on the throttle system itself. Maybe I wasn't clear on the way I envision a DIY mild hybrid. With foot off accelerator fuel is shut off. With foot on accelerator fuel is turned on. That way the driving experience at a stop would be that when the accelerator pedal is touched, the car moves forward. Let off the pedal, and the car slows down and stops because fuel is cut off.
Hooking it up to the neutral switch and having it auto start when shifting out of neutral adds one more detail that would need to be addressed, the system knowing if starting is even necessary since you pass neutral every time you shift gears. You could add a system that when shifting out of neutral starts the engine if engine RPM is below a certain threshold, but again then you have the problem of it self starting when in gear unless you add the clutch switch to the system. But if your clutch cable fails then the system would try to start with it in gear again.
For it to start in neutral you would need a manual way of starting it in neutral before moving the shifter.
I still prefer the idea of a system that just starts if you touch the pedal and cuts fuel if you let off the pedal.
Also, if it's so steep that you can't engine brake down the hill in 2WD that's one of the few times I suggest coasting in neutral or keeping the car speed down to begin with since engine braking is only a problem at higher RPMs. I don't think everyone needs 4WD with low range so they can engine brake down extremely steep hills in the winter.
