Originally Posted by Isaac Zachary
But that brings up another problem. What if you suddenly need to take off? Now you have to start the engine in neutral, then shift into gear and then release the clutch.
That's one of my questions - will the 60-lb-ft torque of the assist motor be enough to spool the engine up to idle speed quickly?
