Old 02-28-2022, 05:17 AM   #42 (permalink)
19bonestock88
IGL - '04 Saturn Ion
Team Saturn
90 day: 56.19 mpg (US)
Made some progress on my L61 this weekend. Finally got the rest of the tools to rip it apart and so I have started. I got the head off(bores look great), removed the primary and secondary timing chains and the balance shafts, worked on installing the balance delete kit (requires hammering a tool into the balance shaft holes to shift the bearings to cover the oil holes) and the shorter secondary chain and the custom chain guide.
Afterwards I brought the cylinder head inside and disassembled it, began port work. GM did a phenomenally awful job casting these heads, there are ledges in the ports, causing reversion in the intake side and eddy currents in the exhaust side. My initial cut was just to use a carbide burr to smooth out these ledges, I’m not going for a radical enlarging or reshaping of the ports
ID:	31744   Click image for larger version
ID:	31745   Click image for larger version
ID:	31746   Click image for larger version
ID:	31747   Click image for larger version
ID:	31749   Click image for larger version
My current Ecotec project...
My last Ecotec project...
The Following 2 Users Say Thank You to 19bonestock88 For This Useful Post:
freebeard (02-28-2022), me and my metro (02-28-2022)
