Old 03-03-2022, 09:49 PM   #16 (permalink)
ksa8907
Volt, gas only - '12 Chevrolet Volt Premium
90 day: 38.02 mpg (US)
Volt, electric only - '12 Chevrolet Volt Premium
90 day: 132.26 mpg (US)
Yukon Denali Hybrid - '12 GMC Yukon Denali Hybrid
90 day: 21.48 mpg (US)
Originally Posted by Tahoe_Hybrid View Post
dude it's going to take a LONG time to fill using a home gas pipe it's better to just use the station they use High pressure gas lines
the house pipe is 10psi that is at the tap
after the meter & regulator it's down to 1psi 7-10 hours fill time... if you had 10 psi at the stove the flame would be 10x bigger
source: talked to the gas man before
Lol, I am the gas man.
Residential delivery pressure is generally 0.25psig. 10psig on a house line would blow up the 2# regs that are built into most appliances and any pilot would be extinguished and blowing gas... and then kaboom goes the neighborhood.
If it's a recent gas line installation, it's probably 1/2 mdpe. I don't recall what the maximum throughput is but it would also depend on your distance from the main. In any case, residential meters will not pass more than about 500scfh.
To the OP, again, the cost to make a reliable and safe compressor will not be economically viable.
