Old 03-09-2022, 10:44 AM   #14 (permalink)
Piotrsko
If the bug has german cloth covered rubber and the original intake seals, that rubber isn't safe for the modified fuel. Right red colored silicone replacement seals and american fuel lines currently are. You'll need about 5 ft of fuel line as there is a lot of it needing replacement. I ignored the vent lines but they should be replaced also.
Kinda want to avoid the dreaded drivers side vent burn pattern.
The Following 2 Users Say Thank You to Piotrsko For This Useful Post:
aerohead (03-09-2022), freebeard (03-09-2022)
