I ask because my friend's Prius has steelies with hub caps that look like that ...except plasticy.
If you're going to use screws, I'd be most comfortable with Helicoil inserts.
The best way is Dzus fasteners. ecomodder.com/forum/.../dzus-fastened-moon-disc-wheel-covers
"If you don't read the newspaper, you are uninformed; if you do read the newspaper, you are misinformed. " someone who was not Mark Twain
