Old 03-10-2022, 10:59 AM   #21 (permalink)
Piotrsko
Older Diesel engines used to rely a lot on the reaction of the sulphur content of the fuel with the nickel content of some alloys used in the manufacturing of the pumps and injectors. On a sidenote, as biodiesel is often pointed out as a lube too, maybe it would be interesting to try Castor-based 2-stroke oil often used in racing karts, which may blend well not only to regular Diesel but also to some higher content of biodiesel.
The consensus preferred is a 1 dollar bottle of walmart 2stroke oil per tank of any fuel in my navistar engined F250, but I think that is a price consideration. Castor oil mixes but doesn't burn (at least in rotary radial engines, hence the scarves favored by the pilots) so it might affect the catalytic converter
