Old 03-12-2022, 10:38 PM   #1 (permalink)
BackroadBomber
Jenny - '02 Chevrolet Prizm Lsi
90 day: 31.45 mpg (US)
Crowley - '23 Ford Maverick XLT
90 day: 24.18 mpg (US)
Moving o2 sensor closer to engine
On my 03 civic ex, in stock form, there’s no o2 sensor on the exhaust manifold. There’s one on the down pipe shortly after the flange, and the catalytic converter is underneath the car with the second sensor screwed onto the back of it. The previous owner replaced the stock manifold with a cheap stainless eBay header. It’s made for several applications, so it has a plugged o2 sensor bung on it. This weekend my catalytic converter decided to rot out and snap in half. The replacement has a plugged bung where it’s supposed to be, right after the flange. I would’ve never messed with it, but as long as i have to remove the o2 sensor anyways, would it be at all beneficial to move it to the header? It would be about 8” closer to the engine. The lower trim level civics have the catalytic converters built right into the manifolds, and the upstream sensor on them are much closer to the exhaust ports, so I’m not really concerned about too much heat or anything. I was thinking maybe it would make the sensor heat up slightly faster to get the car out of rich-running “warm up mode,” or possible the extra heat would then in turn trick the cars computers into making it run slightly leaner? Maybe it will do absolutely nothing and its just wishful thinking? Sadly I’m replacing with a higher-flowing cat, so any gains this next tank could not be 100% contributed to this. I was just wondering what y’all think.
