Old 03-14-2022, 02:32 PM   #12 (permalink)
hayden55
Sport Utility Prius - '10 Toyota Prius II
90 day: 52.98 mpg (US)
300k Sequoia 4WD - '01 Toyota Sequoia Limited 4wd
90 day: 20.19 mpg (US)
Originally Posted by Taylor95 View Post
Surprisingly all these mods seem to have made a big difference. There is a hill I coast down sometimes. I usually only stay the same speed or gain 3-4 mph. Today I gained 10-12 mph going down the same hill. That is a big difference that I hope will translate into mpg gains.
The biggest thing adversely affecting mpg now is acceleration. The vehicle is so heavy that it takes quite a lot of power to get up to speed. One thing I want to do to help this is to switch to a lighter wheel/tire combo. Currently the combined weight is 80 lbs. I can easily go down to 70 lbs and still have the load range E tires that I want. I'm hoping that will make some difference.
When you accelerate do you make a point to keep the trans around 2000rpm or less? My 04 would like to be about 2700 rpms on accelerations but i make a point to let off around 2k so it shifts.
"I feel like the bad decisions come into play when you trade too much of your time for money paying for things you can't really afford."
