Old 03-14-2022, 07:55 PM   #20 (permalink)
Plush1992
War Pig - '01 Ford Taurus SEL
Originally Posted by BackroadBomber View Post
With the stock injectors the fuel trim was between -1 and +1. With the focus injectors it was between -12 and -10. That was only tested at idle, since the obd1 plug was under the hood. If you have time and a cheap u-pull-it junkyard close by, it may be worth a shot.
Thank you! I will 100 percent look into that
First: 2001 Ford Taurus Eco Build Thread
http://ecomodder.com/forum/showthrea...s-33334-2.html
