Old 03-17-2022, 11:01 AM   #3 (permalink)
Blacktree
Blacktree's Avatar
The Prius Experiment - '07 Toyota Prius Base
90 day: 58.52 mpg (US)
Originally Posted by rumdog View Post
Do you think the Grill texture helps aerodynamically?
The more porous the grille is, the more drag it will create. They probably gave it just enough porosity for cooling. Generally speaking, electric motors generate less waste heat than combustion engines. So they can get away with less cooling airflow.
Edit: I'm also curious about the wheels. They don't look like they'd be very aerodynamic.
