Old 10-10-2008, 06:38 PM   #19 (permalink)
NiHaoMike
Originally Posted by cfg83 View Post
lyd -
I agree. I would pay up to $50, but not what they want. Also, it appears to be tied to only one PC. In an automobile situation, your hard disk is at much higher risk, unless you have an über-expensive hard drive that is flash-based.
The ScanXL software is almost cheap enough at $70, but I want to see if I can make my own work first.
CarloSW2
SSDs are way cheaper than they used to be. Just now, a 16GB USB SSD is $35 new from Fry's. 1GB of any common form factor is well under $10.
I'm actually using a 128MB SSD (CompactFlash form factor) in a pfSense machine (Cisco-like router without the Cisco price) I'm building. SSDs use very little power, which actually turned out to be a problem as it dropped the current to the point where the power supply (200w) would not operate correctly. I'm working with a friend of mine to design a new power supply.
I think all the software should be open source if possible. As for hardware, I'd suggest something like an old (Pentium 2/3 or M) laptop with a PSOne LCD running from the TV out. It should be easy to find a used one for cheap, especially one with something like a bad screen that decreases its value but is still usable for our purpose. And it can make a good MP3 player as well. If you want, you can even add in some extras like GPS. Just don't use a Pentium 4 as they use lots of power and will hurt your gas mileage.
If America manages to eliminate obesity, we would save as much fuel as if every American were to stop driving for three days every year. To be slender like Tiffany Yep is to be a real hypermiler...
Allie Moore and I have a combined carbon footprint much smaller than that of one average American...
