Originally Posted by hayden55
I'm running 245/75/17 LRR tires from a jeep on mine. I'm super gear limited but they do okay. Your transmission is much better so they would do excellent on yours. My dilemma is torque converter doesn't lock until 45mph now and the rpms at 70 are still above 2000 RPM lol.
mpg from 265/65/17 to 245/75/17LRR was about 5%
So on Prius i try and stay below 45mph and on Sequoia i try and stay above 45mph lol.
You saw a 5% gain after adjusting for the speedometer difference between the different setups?
Do you happen to know the amount of weight reduced when you made the switch?
