For example, the windshield on the Prius is laid back pretty far. So I had to angle the mirror stalks backward, to clear the A-pillars.
Same holes? Wouldn't a lower sight-line allow moving the mirror down and from the A-pillar.
It's hard to tell from the pictures.
"If you don't read the newspaper, you are uninformed; if you do read the newspaper, you are misinformed. " someone who was not Mark Twain
