Old 03-29-2022, 12:25 PM   #100 (permalink)
Piotrsko
If it's framed conventional, it doesn't need backers. There's wood in the proper places. You can use pretty much anything that will hold a screw: 1by, 2by, plywood, angle, tube, what have you. If you're cheap, you can just float the corners which is how sheetrockers sheet ceilings as long as you dont exceed 24".
