Old 04-02-2022, 09:32 PM   #28 (permalink)
JRMichler
JRMichler's Avatar
Nameless - '06 GMC Canyon
90 day: 37.45 mpg (US)
22 Maverick - '22 Ford Maverick XL
90 day: 39.65 mpg (US)
Originally Posted by pashiner View Post
I've got plenty of top-end power at 70+mph, keeps up with traffic just fine...but is sorely lacking bottom end torque.
I'd like to keep fuel economy as good or better, and will explore aero-mods at a later date.
Another approach is to change the transmission. The late model Chevrolet Colorado has a six speed manual transmission with a wide ratio range. First gear is 4.47:1 and sixth gear is 0.61:1. That's a 7.3:1 ratio range from first to sixth. Drop in that transmission and change the rear end to get the same total ratio as you have now.
You would have a lower first gear, so better ability to start out. And use your tach. It's OK to run it to near redline occasionally. My old Colorado had no trouble accelerating to speed on a short uphill onramp. I just needed to run it to redline in first and second gears, and speed shift.
The Following 2 Users Say Thank You to JRMichler For This Useful Post:
freebeard (04-02-2022), Isaac Zachary (04-02-2022)
