Old 04-06-2022, 09:04 AM   #1 (permalink)
Vman455
Moderator
Vman455's Avatar
Pope Pious the Prius - '13 Toyota Prius Two
90 day: 51.62 mpg (US)
Tycho the Truck - '91 Toyota Pickup DLX 4WD
90 day: 22.22 mpg (US)
Optimizing Aerodynamics of a Truck: Part 1
Read original here, and follow this truck's progress as I test more changes.
I’ve written before about my truck, a 1991 Toyota Hilux. This was my grandfather’s truck years ago; it went to my father and then to various of my brothers before I acquired it last year. It was in pretty rough shape, having sat at the back of my parents’ driveway for several years:
I had it hauled down to a mechanic to verify it would start and run and, several weeks later when I was able to fly out, I drove it back up to my parents’ house and set to work.
After a new timing chain, front axle, brakes, suspension dampers, front valance and rear bumper, and other odds and ends, I drove it over the mountains and back to Illinois.
Coeur d'Alene, ID, just down the road from where this truck was originally sold, in Kingston, ID.
Surprisingly, fuel economy wasn’t that bad! The truck averaged just under 25 mpg. But, I wondered, could I improve that? Is it possible to reduce the aerodynamic drag of a truck like this? Measurably reduce drag?
Making a Plan
Unlike my modifications of earlier cars, where I had followed conventional Internet wisdom and guessed at what to change, I wanted to test and measure the changes to this truck.
To do that, I decided to use throttle-stop testing to measure changes in drag directly. I wired in a throttle position sensor display and built a simple, adjustable stop that fits under the throttle pedal. This allowed me to hold the throttle opening at a constant angle, limiting engine power and giving the truck a top speed adjustable from ~90 kph to ~100 kph.
Next, I read several papers on CFD studies of generic pickup trucks, wind tunnel testing of a Ford Ranger, air dam and cooling drag optimization of the 2015 Ford F-150, and the development program of the 1988 Chevrolet C/K (which turned out to include a very interesting parameter study of a wind tunnel model). I made a list and sketched several devices I wanted to try: a deep front air dam, a tailgate spoiler, a cab roof spoiler, grill blocking, mirror removal, rear wheel air dams, and a tonneau cover.
Testing
First, I needed to verify that the throttle stop would give me good, repeatable results, allowing me to use this method to measure drag changes. I identified a few miles of straight, flat, low-traffic road (plentiful around here, fortunately) and went out several times, refining my technique each time until I was able to get good repeatability. Testing windows up against windows down, I found the following changes in speed at different throttle openings:
This suggests that lowering the windows on this truck increases drag by around 4-5%. I can’t be any more exact than that—but there’s no need! In real-world conditions, there’s too much natural variability to be as exact as a wind tunnel or CFD; what I’m after is seeing whether a change decreases or increases drag and approximately how big that decrease or increase is. An important benefit of testing in the real world is that these are the conditions the truck actually drives in: windy, on a real road, in a turbulent atmosphere, past trees and buildings and windbreaks and other cars.
Just as important, the consistency of the results showed that this method would indeed allow me to measure drag changes.
First Modifications
Since the windows up/down check was successful, I tested two simple changes to begin, in the same session: removing the external mirrors and blocking the air intakes at the front of the truck. I used the largest throttle opening to magnify the changes in drag and hopefully be able to measure them.
Mockups for testing don't have to be pretty! Make them quickly and cheaply; you don't want to spend a lot of time and effort on something that turns out not to work.
Results were as follows:
These are about what I anticipated; trucks are higher drag than cars, and on this truck—with its fairly small mirrors and grill opening—we should expect that changing these will have less effect than on a more streamlined car, where they will likely account for a higher percentage of the overall drag.
One interesting thing to note is the result of blocking the grill and removing the mirrors at the same time; there may be some interaction there, or it may be that the actual change of both parameters isn’t enough to show up in my measurements when added together. I expect subsequent tests (air dam, spoilers, etc.) to show greater change than these two, which means they should show up more clearly in results.
Fabrication
Since these first tests showed that blocking the cooling air opening and removing the mirrors would in fact reduce drag, I went ahead and made the changes permanent. I had to make a blanking plate to cover the mounting holes for the stock mirror, so first I traced the outline onto a piece of scrap paper:
Yes, those are the installation instructions for the driving lights. Remember what I said about being cheap?
Then I cut that out and traced it onto thick plastic sheet, trimming that carefully with a pair of shears:
If you're careful, shears can be a very versatile and delicate tool. Cheap plastic can be procured by purchasing storage bins and cutting them up.
And finally, I caulked it into place:
That looks "almost professional," as we used to say in one organ shop where I worked.
For the grill block, I reinstalled the sheet aluminum pieces I had fabricated over the winter (the 22R-E is a cool-running engine, and I wanted to speed warmup times and keep as much heat in the engine as possible; now I know there's an aerodynamic benefit as well):
The grill isn’t blocked completely, but the lower grill has just two small openings and only the center section is open on the upper grill. I’m happy with the small drag reduction this combination of mirror removal and grill blocking gives; the bigger gains will come in the future with air dams and spoilers.
UIUC Aerospace Engineering
www.amateuraerodynamics.com
The Following 8 Users Say Thank You to Vman455 For This Useful Post:
aerohead (04-07-2022), BamZipPow (09-16-2022), Drifter (04-10-2022), freebeard (04-06-2022), Gasoline Fumes (04-06-2022), MeteorGray (04-12-2022), M_a_t_t (04-06-2022), Whitworth (04-14-2022)
