Old 04-09-2022, 01:21 PM   #14 (permalink)
M_a_t_t
マット
M_a_t_t's Avatar
The Van - '95 Chevy Astro Cl V8 Swapped
Team Chevy
90 day: 7.84 mpg (US)
The new bike - '17 Kawasaki Versys X 300 abs
Motorcycle
90 day: 71.94 mpg (US)
The Mercury - '95 Mercury Tracer Trio
Team Ford
90 day: 34.35 mpg (US)
Toyota - '22 Toyota Corolla Hatchback
90 day: 40.11 mpg (US)
You could just wait til you have the camper (didn't see it in this thread so I don't know the details), then put a thin board loosely attached to the bottom (using something like an F-clamp) that would represent the lowered body. Then pull the camper around hitting some bumps. If you "bottom out" the axle then the board will move. This way you can test how using a similar spring rate while only lowering it would affect it.
I've got my van lowered 2" and I tow a car trailer every once in awhile (up to 4200 lbs). The van is only rated for 5500 lbs so I'm close to the limit. Unless you are maxing your tongue weight capacity out then I think you will be fine.
1973 Fiat 124 Special
1975 Honda Civic CVCC 4spd
1981 Kawasaki KZ750E
1981 Kawasaki KZ650 CSR
1983 Kawasaki KZ1100-A3
1986 Nissan 300zx Turbo 5 spd
1995 Chevy Astro RWD (current project)
1995 Mercury Tracer
2017 Kawasaki VersysX 300
2022 Corolla Hatchback 6MT
https://www.youtube.com/channel/UC6s...LulDUQ8HMj5VKA
The Following User Says Thank You to M_a_t_t For This Useful Post:
Taylor95 (05-04-2022)
