Old 04-11-2022, 11:56 PM   #6 (permalink)
cRiPpLe_rOoStEr
Originally Posted by new_bug View Post
1800rpm plate no throttle
You'd need the injector pump to be fitted with a variable-speed governor, set for a higher RPM too. Otherwise the engines are exactly the same, regardless if it's rated at 1800 RPM or 3000 RPM.
