Old 04-14-2022, 06:06 PM   #126 (permalink)
aerohead
delta-Cd
Originally Posted by Drifter View Post
I was taught low speed Cd was "fixed" in my undergrad fluid dynamics course 20 years ago, but I've subsequently learned it is more complicated than that. For time trial cyclists, it is not uncommon to see Cd change 0.0015 between 30mph and 20mph. An elite time trialist might have a CdA of 0.180 so we are talking about less than a 1% difference, but in high level competition that can make the difference between 1st and 2nd.
And that is just for 0-yaw in the wind tunnel. Out in the real world there are crosswinds and the slower you go, the higher the yaw angles you will encounter:
The ideal shape of your vehicle/object changes depending on the expected yaw angles. About 15 years ago Freightliner and International each released totally redesigned semi's. Freightliner boasted that its Cascadia was ~8% more aerodynamic than International's Prostar, which it apparently was a 0 degree yaw wind tunnel. Out on actual highway loops in Colorado & New Mexico cross winds, the Prostar was ~5% more aerodynamic.
Freightliner Cascadia (8% better aerodynamics in a straight line wind tunnel):
International Prostar (~5% better aerodynamics in real world cross winds):
Thanks.
As a production automobile, for it's length, reaches critical Rn around 20-mph, you might imagine that, with the length of a bicycle, it will be at sub-critical Rn until a higher velocity is achieved.
So it's no surprise to see Cd variability with the bike.
As amateurs, with no 'means', we may just have to resign ourselves to the fact that driving weather will be whatever it is, with no control over crosswind or gusts.
Current automotive Cds are already 'crosswind-averaged', figuring a mean annual averaged 7-mph crosswind vector.
We'd be looking at $4,000 /hour to validate a Cd in a full-scale tunnel, zero-yaw, or crosswind.
