04-14-2022, 10:08 PM
Brain food:
Pontiac Tempest
The Tempest featured a drivetrain with a rear-mounted transaxle[8] that was coupled to a torque shaft arcing in a 3 in (76 mm) downward bow within a curved, longitudinal tunnel. Use of the torque shaft was the result of being forced to use the Corvair floorpan which, being a rear engine platform, had no drive shaft.[4] To combine flexibility with strength in the proper proportion, the shaft was forged of SAE 8660 steel (high nickel, chrome and molybdenum alloying percentages) for torsion bar specifications. For automatic cars, the shaft was 0.65 in (17 mm) in diameter and 87.25 in (2.216 m) long, while the manual-box shaft was 0.75 in (19 mm) by 82 in (2.1 m). This joined the forward engine and the rear transaxle (therefore no transmission hump) into a single unit, helping to reduce vibration.[9] The design, known as "rope drive," had only been seen previously on General Motors' 1951 Le Sabre concept car.[10]
Porsche 924
The original design used an Audi-sourced four-speed manual transmission from a front wheel drive car but now placed and used as a rear transaxle. It was mated to VW's EA831 2.0 L I4 engine, variants of which were used in the Audi 100 and the Volkswagen LT van .... The four-speed manual was the only transmission available for the initial 1976 model, later this was replaced by a five-speed dog-leg unit. An Audi three-speed automatic was offered starting with the 1977.5 model. In 1980, the five-speed transmission was changed to a conventional H-pattern, with reverse now on the right beneath fifth gear.
