Old 04-14-2022, 11:56 PM   #136 (permalink)
Phase
Phase's Avatar
Black Bullet - '19 Hyundai Ioniq Hybrid Blue
What do you think? duckduckgo.com/?q=3mm+ABS+4x8+sheet&iax=shopping&ia=shopping I see prices in the $70-80 range.
Then you have the structure. Composite sheet would need some as well, but it's pre-finished. So long as it doesn't get scratched up in fabrication, there's a big savings compared to fiberglass and likely ABS.
I don't trust this link but it's interesting: https://www.alibaba.com/pla/3mm-pe-d...dmRpZD05MTY2OA
If you truncate it after .html is fails to a search page, but the append calls out a Google search while I found it on DuckDuckGo. Anyways, those architectural panels they make Toyota dealerships out of cost the contractor less than $10 in quantity.
i probably wont need THAT much in material for the rear spoilers. im mostly looking at abs for the undertray, unless you have some suggestions
spoilers will probably need to be a bit stiffer since they can only be mounted at the tip of the car
