Thread: Side Mirrors...
Old 04-16-2022, 09:39 AM   #9 (permalink)
Vman455
Moderator
Vman455's Avatar
Pope Pious the Prius - '13 Toyota Prius Two
90 day: 51.62 mpg (US)
Tycho the Truck - '91 Toyota Pickup DLX 4WD
90 day: 22.22 mpg (US)
I siliconed plastic covers on the truck:
On the Prius, which has door-mounted mirrors, I fiberglassed over the hole:
Before you fit smaller mirrors, test them to see if they are actually lower drag than the larger stock mirrors; they may or may not be. Something like this will tell you which mirror has lower drag (the one further from the pole's centerline when there's no torque developed):
But that isn't the whole story; you'll also need to investigate whether the lower-drag mirror by itself is also the lower-drag mirror next to the car, where there is interference between the mirror and body.
UIUC Aerospace Engineering
www.amateuraerodynamics.com
The Following User Says Thank You to Vman455 For This Useful Post:
Drifter (04-16-2022)
