Originally Posted by Drifter
The goal is to decrease oil use, not fuel consumption. You're replacing ~15% of oil-based gasoline with plant-based ethanol (which should lower mpg ~7% compared to pure gasoline).
If I'm doing my math correctly, the net result should be America using ~9% less oil to drive the same amount (but paying more to do so)
that is canceled out by lowering the mpg Net savings is zero possibly negative depending on how the car reacts to it
if i get 3mpg less because of it then i'd drop down to about 16 instead of 22 with real 100% gas
