Old 04-21-2022, 10:59 AM   #7 (permalink)
aerohead
Ranger wheelhouses
I recommend that you inspect the wheelhouses of modern passenger cars.
Those features would be your Go NoGo for the Ranger project.
Aerodynamic streamlining involves a 'system'.
Not to be insensitive, but, the wheel arch seals, in light of the full-turbulence environment their embedded within, aerodynamically, would constitute 'lipstick on a pig.'
1) You'd need to run the front wheels full their full range of motion to establish needed wheel clearance.
2) Fabricate full inner fender wells, just like in 'cars.'
3) The inner walls need to drop as low as the wells.
4) The OEM cooling system, down-stream flow from the radiator needs to be understood, and respected in the new additions.
5) The wheel arch gap-fillers need to be as 'tight' as you can make them.
6) Ford Motor Company says that full front skirts ( like Probe-IV, Probe-V, Aero 2002A, AEROCIVIC ) offer the highest drag reduction )
