Old 04-22-2022, 12:48 AM   #185 (permalink)
Phase
Phase's Avatar
Black Bullet - '19 Hyundai Ioniq Hybrid Blue
1) First, you need to scout out opportunities for attachment points.
2) The fuel tank needs to be 'fire-walled' away from exhaust heat.
3) Metallic heat shields can be fabricated and attached to the hidden side of belly panels.
4) The exhaust pipe itself wrapped in fiberglass racing wrap.
5) The lower A-arms of the rear suspension may be able to carry their own belly panels.
6) Everything which doesn't 'move' can have a frame structure attached below, from which the skins are secured. This will also define the upsweep of the diffuser section.
7) Aluminum, directly under the muffler would be immune to its heat.
8) A dual mirror delete would be in the neighborhood of delta Cd 0.0125
9) Rear skirts netted Covington Univ. delta-Cd 0.0063 ( 2.1% ), perhaps an okay working number.
10) The rear belly section with slow diffuser (2.8-degree) was delta-Cd 0.02 ( Audi & FIAT ) if memory serves me.
If so, we're looking @ an est. Cd 0.2012.
If we were millionaires we could actually know.
whats the cheapest way about going about the rear section? im doing this to save money in the long run
kind of bummed that wheel skirts have a smaller impact than simple side mirrors
The Following User Says Thank You to Phase For This Useful Post:
aerohead (04-25-2022)
