Old 04-23-2022, 06:04 PM   #2 (permalink)
Isaac Zachary
High Altitude Hybrid
Avalon - '13 Toyota Avalon HV
90 day: 40.45 mpg (US)
Prius - '06 Toyota Prius
I jumped through it in parts so didn't see it all. But I do agree with him to a degree.
Carbs do have an advantage of getting fuel to atomize more due to the distance, and therefore time, that the fuel needs to evaporate in the intake. Direct injection leads to more particulate matter, a by-product of liquid fuel droplets in the combustion chamber.
But angles and turbulance actually tend to be enemies, not friends to atomization. Any liquid that spins tends to spin out of suspention and pool.
Perhaps the most ideal intake would be one that has a single straight runner into each cylinder with a single carb at the end. Also, with the intake designed more for average power, not full power. You want your intake runners as thin as possible to keep air speed up and therefore atomization. Big intakes with a central carb let the air thru slowly at cruising speeds which lets fuel fall from suspention.
The cross-plane V8 design also is more balanced than an inline 4 cylinder or a V-6. The balancing helps reduce vibrations without the need for balancing shafts. Both balancing shafts and vibrations sap away energy resulting in reduced power.
The Following 2 Users Say Thank You to Isaac Zachary For This Useful Post:
Ecky (04-23-2022), mpgmike (04-27-2022)
