Old 04-24-2022, 07:53 PM   #411 (permalink)
freebeard
[citation needed] I guess.The part about harmonics and heat needs some explication. Everything silicon based I've seen stacks cells responsive to different wavelengths to get to 40%.
You doubt foil-printable organic transistors? Wikipedia define Rectenna as used in power transmission. As it's used here, combined rectifier and antenna at a nanoscale resonant to light's wavelength.
