Originally Posted by 65whitelion
Air flow around the rear is a major issue.
Drivers of the sedan version are commonly getting 10-15% better fuel consumption.
Something needs to be done about the flow on the sides of the car at the rear.
Full wheel spats with something behind to separate the flow would be good, but probably won’t be happening.
Looking for something like a small, self-adhesive gurney flap to clean up flow on the sides.
I will have to work on a picture to show this better.
G'day 65whitelion.
In regards to air separation edges at the rear corners, I'd try some adhesive weather strip (with a triangular section) as an inexpensive trial.
I've bought some at Bunnings in the past.
