Old 04-27-2022, 12:21 PM   #16 (permalink)
rmay635703
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
We should look at 'what works' ( Matt Damon ).
I can't envision vertical, multi-mile length copper pipe. I don't think it has the tensile strength to survive.
Pex, as with Poly Vinyl Chloride couldn't hold up to the heat.
If you have ever used a hose to empty a gas tank…,
If you pull it up and maintain a seal it can be easily pumped up and back down to the same level, you could then directly use the heat differential between it and ambient using a PEG or similar, no turbines required
Although I can’t find the article there are new designs for aerospace that can work at near 100% efficiency and extremely high temperatures.
https://www.science.org/content/arti...at-electricity
