Unless you're in a lab environment, you're going to need thousands of samples to see a trend. Everything else is just variability in the test.
Edit: I really like PF channel, I also skipped to the end of the video. So he saw less internal friction and it did seem to coat the internal components. But no test for fuel consumption
If this product were so great, all the Mfg's would use it to get better MPG numbers.... just saying.
