My air conditioner is going to be a hard fix, I had a collision with a very large wild dog on the highway at around 60mph, this crushed the entire front end in destroying my radiator and AC condenser in the process. When I fixed it I got a half sized radiator for replacement to make room for possible upgrade to a turbo later on but the radiator is slightly too tall so for now I had to tilt it forwards to make it fit which is taking up the room the AC condenser is supposed to be in. I have a possible solution but it requires replacing the entire front support with a smaller one I have on my spare car. Second issue is AC control panel is busted and they cost around $450 for a new one. Third issue is I don't know if any of the present components for the AC work or not since the AC lines were all missing when I purchased the car and I had the accident right after I purchased them.
TLDR: AC needs A LOT of work.
