Old 05-07-2022, 06:14 PM   #2 (permalink)
ksa8907
Volt, gas only - '12 Chevrolet Volt Premium
90 day: 38.02 mpg (US)
Volt, electric only - '12 Chevrolet Volt Premium
90 day: 132.26 mpg (US)
Yukon Denali Hybrid - '12 GMC Yukon Denali Hybrid
90 day: 21.48 mpg (US)
I wish you the best of luck.
Pumping losses are directly attributed to high vacuum. Which is why diesels have low pumping losses.
Most high efficiency engines/hybrids use a cam profile or cam phasing to achieve late intake valve closing. This gives lower dynamic compression ratio but increases the expansion ratio.
