Old 05-07-2022, 08:06 PM   #2 (permalink)
freebeard
The first turbocharged cars from GM used ethanol to counter detonation.
https://www.oldcarsweekly.com/features/olds-f85-jetfire
The little Jetfire was based on Oldsmobile’s F-85 series. As a result, it used the same aluminum-block 215-cid V-8 that survives to this day in the British Land Rovers and Range Rovers (albeit bored out a bit).
Oldsmobile added a waste gate, kept this engine’s 10.25:1 compression ratio and suppressed detonation with a water-and-alcohol injection system. This system included a tank under the hood for “Turbo-Rocket” fluid. The turbocharger’s boost was limited to 6 psi.
You can't be wise and in love at the same time. -- Bob Dylan
Piwoslaw (05-08-2022)
