Thread: DIY heat pump??
Old 10-12-2008, 02:51 PM   #28 (permalink)
Mara
Concerning the single hose portable AC, those work well as long as outside temperature is not too cold or too hot. As you figured out they cause vacuum to your house and replacement air is coming from the leaks of the house. I do not use these if outside temp is below freezing, or above 100F... In those conditions the efficiency becomes miserable.
