It's never just the head gasket on an aluminum engine.
It's usually a warped head and possibly the block too.
Assuming coolant has leaked into those cylinders for thousands of miles they are likely badly tapered. The old engine is a boat anchor.
If you pull the heads off the newer engine you will be able to see how low miles it really is.
