Old 05-09-2022, 01:52 AM   #10 (permalink)
cRiPpLe_rOoStEr
Originally Posted by Postal268 View Post
I designed my own sort of swamp cooler last year where I had a small cooler filled with ice and a small fountain pump that would pump the ice water through some copper tube that I coiled in-front of a fan. Issue one is tipping over and leaking but could have solved by tying it down. Issue two was the fan was too small. Issue three was the cooler was too small so all the ice melted within an hour. Just all around it was too small and too much work for not enough results.
Swamp-coolers available commercially in Brazil are different, usually fitted to the roof of a truck as a self-containing unit, while others have an external water reservoir. They might not be exactly the most beautiful setup, but it's still common here.
https://engineeringworkarounds.blogs...-in-truck.html
https://engineeringworkarounds.blogs...window-t2.html
https://engineeringworkarounds.blogs...udget-yet.html
