The only turbo blankets that I have ever seen were more of a protective device to prevent a mechanic to burn a hand than something actually meant to increase thermal efficiency of a turbocharging setup, yet a thermal insulation tape around the exhaust pipes used to be a quite common performance-oriented mod which ended up effectively helping to keep the engine bay temperatures under control.
