Old 05-11-2022, 10:27 AM   #2 (permalink)
Piotrsko
Most chocks I have seen are about a 6x6 cut on a 45 degrees, some with a radii on the hypotenuse. The whole point is to use the vehicle weight climbing a steep hill to prevent movement. Walmart chocks seem to fit everything from 6.00-6 aircraft tires to 22" dualies, but I wouldn't use them on the dualies since they would probably collapse from the weight. Add a bungie system to keep them tight against the tires and it aint going anywhere but needs tiedowns just because.
