Old 05-11-2022, 10:05 PM   #69 (permalink)
Drifter
Cx9 - '18 Mazda CX9 Grand Touring
90 day: 31.41 mpg (US)
Prius - '10 Toyota Prius III
90 day: 57.8 mpg (US)
Tundra - '00 Tundra V6 long bed base work truck
90 day: 19.4 mpg (US)
I suspect, but don't know, that regen efficiency will vary depending on regen rate and battery state of charge. I've read that this is the case for motor output so I assume it is the same in reverse...
As for throttle, on my gen 3 there is no 1 pedal position that coasts. Above ~10mph with the accelerator pedal off, the generator regens slightly to mimic an automatic transmission's drag. From ~5mph to 10mph, zero pedal coasts. Below around 5mph, zero pedal actually applies a little bit of power to creep forward (again like a normal automatic).
