Old 05-11-2022, 10:21 PM   #70 (permalink)
ps2fixer
92 Camry - '92 Toyota Camry LE
90 day: 26.81 mpg (US)
97 Corolla - '97 Toyota Corolla DX
90 day: 30.1 mpg (US)
Red F250 - '95 Ford F250 XLT
90 day: 20.34 mpg (US)
Matrix - '04 Toyota Matrix XR
90 day: 31.86 mpg (US)
White Prius - '06 Toyota Prius Base
90 day: 48.54 mpg (US)
For the little amount of throttle input to get it in to coast mode, I suspect wouldn't be much of a difference for the creep speed at basically stopped speeds. Assuming it's smart enough to stop the creep current when the brakes are applied harder, I don't think it would be too much of a down side. Would be less wiring involved which would be a lot nicer to hook up.
I guess the TPS is kind of a bad indication since the pedal isn't hooked to the engine directly. Not sure if there's a read out for the pedal input. I might have to pull my scope out again and record the voltage for coast. Over 41mph is a little hard to tell when it's costing since the on screen display still shows power flow. If I remember right, arrows pointing to the engine from battery is roughly the point that it's in coast mode. I guess it's using battery power to keep the engine spinning to keep the rpm's in check. I wonder what's different between that and neutral coasting.
