Old 05-12-2022, 11:07 AM   #259 (permalink)
aerohead
why?
Originally Posted by Phase View Post
Can anyone explain why the new Mercedes EV that gets 1000km of range is 2 points lower in drag than the xl1? Heck the xl1 has a longer boat tail, is narrower, rear wheel spats, and deleted the side mirrors
The Mercedes keeps the side mirrors and doesn’t use rear wheel spats!!
1) There were dozens of subtle aero optimizations performed on the M-B EQXX.
2) And the EQXX is actually 12% 'longer' than the XL1, where it counts.
3) At a difference of 14.4-counts, each little 'cut' for the Mercedes made up the difference.
4) And as others have already mentioned, the EV's 'engine' is up to 350% more efficient than the VW's Diesel. That makes for less heat flux, less cooling load, more time the active radiator shutters are 100% closed.
5) For it's drag coefficient, the XL1 has the worst shape compared to 1937 Schl'o'rwagen, 1987 GM Impact, or 1987 Renault VESTA-2.
6) Too much 'nose', not enough 'tail'.
