Originally Posted by redneck
Welcome.
The first thing you need to do if you do not already have one is to purchase a instant mpg gauge so you can see what’s happening as you drive in real time. There are several you can choose from “ultra gauge”, “scan gauge” and or several apps such as “torque”.
Your biggest gains will come from adjusting the nut behind the wheel. Start working on that immediately. That way as other improvements are added, they will be amplified.
Suggested reading.
https://ecomodder.com/forum/EM-hyper...ecodriving.php
Then move on to improving to your vehicle.
https://ecomodder.com/forum/fuel-eco...ifications.php
Again, welcome.
Have a great day...
I'm working A LOT on the nut behind the wheel, I've been reading this link few hours before you shared it. I learned few thinks that I wanna try like the pulse and glide technic.
I already have Torque Pro, I used it for OBD2 reading mostly and for some complex diagnosis where I needed to go deeper on data. I downloaded the "better dash" add on, I hope it will be a lazy way to improve my skills. If not then I'll make my own dashboards on Torque
